36
This discussion topic is read only This discussion topic has been answered Discussion topic: Cancelling Sky TV
This message was authored by: BarbaraP1
Cancelling Sky TV
How do I can my SKY TV subscription in Ireland. There's no contact number on the website.
This message was authored by: Mark39 Answer
Re: Cancelling Sky TV
Try using your browser's incognito/privacy mode. Might be a cookies issue.
Locked
There is click https://www.sky.com/help/articles/cancel-sky-tv#still-need-hand
At the bottom of the page change the flag from UK to Ireland, then select Need More Help, there are a number of contact options then presented to you.
@BarbaraP1 You can’t cancel all or part of your subscription via the forum. You need to contact Sky. You can ring or use the messenger service. This link will help you https://www.sky.com/cancel
Once you’ve returned all loaned equipment remember to keep your proof of posting very safe.
Change the flag in the bottom right to ROI.
Avatar for BarbaraP1
I've followed the link and there are no numbers being displayed for contact after clicking "Still need a hand"
I've followed your instructions but there are no contact numbers coming up after clicking on "Still need more help"
You need to click the Blue Boxes for each option, did you do that?
This message was authored by: Bobby+Dylan
I'm the same, I went through all the options. It then said a phone number would show but nothing showed.
Why is it so hard to speak to someone?
There's no option to click anything appearing on the screen
I don't know why they can't make it clear! It's crazy.
@BarbaraP1 @Bobby+Dylan  Try this link
https://www.sky.com/help/home
scroll down to the very bottom change the flag in bottom right hand to relevant country first, then click the need more help and the number will show at the bottom of that section
@GD1 I've tried your link and mine and surprisingly no number is coming up for me either for ROI options.
@BarbaraP1 @Bobby+Dylan Perhaps you could try again later or tomorrow.
@Daniel0210  @GD1  Try the link I've posted and see if that works for you both
@SKY1992bf  Works fine here using Google chrome
No it still doesn't work. Regardless of what browser is used
@GD1  @Daniel0210  If people are struggling to find the number via the cancel link then the link I posted might be the easiest answer
Locked
