Discussion topic: Broadband Problems 19/9
Message posted on 19 Sep 2023 11:26 PM
Re: Broadband disconnected??
Legend! You absolute wizard. Sorted my tv not the internet. Will I need to change back from 8.8.8.8? Thanks 🙏🏽 @sandoc
Re: Broadband down again
Same as you all down here in Kent too
I'm in Exeter and all my sky services are down (broadband, glass and app) also cannot sign in as says incorrect password even though it is not.
Sky disconnected
Sky down once again, Basildon area how to even fix when broadband checker out. My lights are green, when I checked no Internet is connected even using a cable still no good. What am I paying for on sky, when you can't even ring sky or sort the problem.
Broadband down in Hove
Sky Glass TV went down yet again - very annoying. Supposed to be cutting edge technology but have had nothing but trouble with it - stick to a Sky box if you have one! Settings on tv stated broadband was down when it wasn't. Online Sky advised to reset router. Reset, unplugged router and tv, did everything as directed. The last light on router remained orange, so still no tv and broadband! Very frustrating, all when the cost of Sky keeps going up for a very poor service.
Broadband down in Gosport too.
What is annoying is no call lines answering, say technical fault and no mysky app or service status working either.
Internet gone two green lights and one amber voice light nothing since about 10.15 pm what's happene
No internet service gone two green lights and voice on amber nothing happens when follow intructions to re connect what gone on?
Same in ox11
Mine has been gone for an hour. SE23.
Re: My broadband is not working
My networks down since 22.30 in Northampton. Must be all of sky.
The sky network status displays all is good....🤣🤣🤣
Broadband down in DE65
No internet connection and can't run test via website. Has been down for about 20 minutes I think.
You can connect sky box to your phones hotspot?
And BR2 NO INTERNET
Re: Is internet is down?
Down in CW7
Hi. I'm in Birmingham B30 area and my internet went down about 30 mins ago. Reboot of the router has done nothing. Too bad nobody from Sky can tell us what's up!
