9
This discussion topic is read only This discussion topic has been answered Discussion topic: Broadband Outage
This message was authored by: SPBS
Broadband Outage
Hi,
Last night I had a broadband outage, the power and wireless LED's were green on the Qbox, but the internet LED was orange. Went through the usual checks, unplugging and resets, but nothing. This morning all green LED's were back on, but the download speed was 45mbps, a little low than nornal. But the upload speed was very, very low, 1.3mbps instead of around 16/18mbps. Is there anything I can do as I need a good upload speed for my live streams.
Steve
This message was authored by: cookiemonsteruk Answer
Re: Broadband Outage
@SPBS
After an outage it can take 24-48 hours for device/throughput speed to normalise.  Your downstream could be a bit better but still likely above the minimum. Your minimum download will be in more about your connection
Locked
@SPBS
Can you post your router stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
And post the results from my sky app->run tests->more about your connection
Avatar for SPBS
Level 3 icon
Thanks CM UK,
Router Statistics
System Up Time: 08:47:59
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 30124160 30872685 0 16091411 519560 05:49:07 LAN Up 15193450 15184085 0 701183 15826761 08:47:59 WLAN (2.4 GHz) Up 466104 182932 0 14015 1917 08:46:20 WLAN (5 GHz) Up 2039506 1148092 0 557451 79202 08:46:19
Broadband Link Downstream Upstream Connection Speed (Kbps) 60000 16841 Line Attenuation (dB) DS1:13.8    DS2:32.7    DS3:49.9 US0:5.2    US1:25.9    US2:38.6 Noise Margin (dB) DS1:7.4    DS2:7.4    DS3:7.3 US0:5.8    US1:5.8    US2:5.8
@SPBS
Avatar for SPBS
Level 3 icon
Many thanks for your reply.
My main worry is that the upload speed (unless it goes back to what it was before) is very low, my current package is 59Mb/s download and 16Mb/s upload or thereabouts. I am currently a good 13Mb/s short.
Is there any point to resetting the hub or changing anything in the router settings?
Steve
@SPBS
As mentioned already sometimes DLM needs a good 48-72 hours to sort itself out, especially after a fault fix.
One thing you can try is to switch the router off for 20mins, this will issue you a new public IP.
I am NOT a Sky Employee
Avatar for SPBS
Level 3 icon
Many thanks for your input. I will wait and see.
This message was authored by: JPR007
@SPBS Your line is synced at 16.8Mb upstream according to your stats, so it's a throughput issue. How are you devices connected WiFI or ethernet? If you rely on a PC for streaming duties etc, you should be using ethernet not relying on WiFI.
Try what @jamesn123 suggested, leave the router off for at least 30 mins, this will ensur you are allocated a new IP address.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for SPBS
Level 3 icon
 I am testing on my ethernet connected PC, always had around 16Mb/s upload speed.
Will wait for it to settle down, I have no idea why is broke last night, I didn't do anything, honest 🙂
@SPBS It was most likely overnight maintenance by Openreach, a necessary evil much like roadworks. No connection or provider can ever gaurantee 100% uptime.
Go ahead and try switching the router off now for half an hour if this is feasible. I had the same a few months ago where my speed halved, despite the router not even dropping the broadband connection. That did the trick and it's behaved ever since.
Locked
