The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
21 Oct 2021 07:41 PM
Hi
could anyone tell me what the best wall bracket is for the sky glass 55 inch please.
Thank you
29 Oct 2021 10:22 AM
Pretty much any VESA mount that will support 300x200, and will hang up to 20kg for the Small, and up to 30kg for the medium, 40kg for large. Don't scrimp and get one which is bang on the weight, they typically don't move nicely if they're super cheap.
21 Oct 2021 07:46 PM
I bought an Invision wall mount off Amazon for £24. I wanted my TV in the corner - so it had to have a long reach. It's more than sturdy enough - it's screwed into timber batton in a stud wall. Vesa is 300x200.
21 Oct 2021 08:11 PM
It you are putting it on a flat wall you can use the wall mount that comes with the TV.
21 Oct 2021 08:37 PM
That's great has anyone got a picture of it and dimensions? Please
29 Oct 2021 10:17 AM
@S44TUH Was this easy to put up? I have read lots of confusion about spaces etc from other posts on certain topics.
i have an exisiting Cantilever bracket from my existing TV which is pretty much like what you purchased off amazon, so i owuld like to think it will work with it!
23 Nov 2021 08:41 PM
How do u mount to flat wall with bracket provided please @DrMips
04 Dec 2021 09:58 AM
Hey!
did you attach the rectangular metal wall bracket onto your mount? Or did you just screw straight into the VESA holes?
thanks!
25 Dec 2021 10:22 AM
I see someone said you can use the bracket on the wall that comes with the tv so how that work please
