Discussion topic: BT Sports 1 not working
This message was authored by nimhysully This message was authored by: nimhysully
We keep getting a message that the channel is effected by a problem with the satellite signal but this channel has never worked and is the only one of the sports package channels that shows this message. We have tried restarting the box and all other solutions that the help button offers us but no joy.
Locked
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Re: BT Sports 1 not working
Posted by a Sky employee
Hi there, how do you pay for the BT Sports, is it via Sky or BT directly?
Lisa - Sky Tech Team Expert
nimhysully
We pay through Sky @Lisa-P1987
This message was authored by ozsat This message was authored by: ozsat
HD or SD?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
nimhysully
SD I would say. We have a pretty basic TV.
What does Horror on 317 look like?
And BT Sport 3?
nimhysully
Same message, the channel is currently affected by a problem with your satellite signal
nimhysully
@Lisa-P1987 What does this message mean? Is it a HD vs SD issue??
@nimhysully that message means you are having issues with your signal.
This message was authored by Kevin+j+v This message was authored by: Kevin+j+v
@nimhysully @I had the same issue, BT sport 1 and 3 run off the same transponder so check that BT sports 3 is not showing the same message, I believe the horror channel and London live also run off that transponder.
Are you using sky q from a communal dish?
nimhysully
Can the signal be fixed?? @Lisa-P1987
This message was authored by Doc5907 This message was authored by: Doc5907
Hi @nimhysully
You will have to give Sky a call and get an engineer out to check and possibly fix your dish alignment.
Sky Q 1TB UHD
LG TV
Sky Mobile
Locked
