Discussion topic: Adding an access point
Message posted on 07 Jun 2021 10:46 AM
Hello,
I have just had my loft converted and have an ethernet cable running up there. I want to add an access point to the current network so that I can seamlessly connect no matter where I go in the house.
Does any one have any suggestion what would be the best hardware to do this?
Message posted on 07 Jun 2021 10:58 AM - last edited: 07 Jun 2021 11:02 AM
Re: Adding an access point
If Sky is your ISP, the Sky wireless booster which matches your Hub model can be a good option (if you can source one).
Personally I use cheap TP-Link APs as I've no need for anything better at home: at work I've got around 40 Unifi UAP-AC-LRs, but that's another story. If I upgrade at home, it will probably be with these as I like having ethernet ports available.
Be careful that whatever you get is actually an access point and not a router.
Message posted on 07 Jun 2021 10:59 AM
If you entire house is run thru the same mains circuit wifi enabled powerline adapters will route the packets via your electrical wiring
Message posted on 07 Jun 2021 11:46 AM
@cookiemonsteruk Is having the powerline adapters better than having an access point plugged in to my main router via ethernet? Or is it essentially the same?
Message posted on 07 Jun 2021 11:49 AM
Similar powerline adapters act as ap's but only require enough ethernet cable from router to plug and plug to device
Message posted on 07 Jun 2021 11:56 AM
Just re re read. If ethernet already in place then just an access point near the device will suffice
Message posted on 07 Jun 2021 11:59 AM
Something like this router that supports access point mode
https://www.amazon.co.uk/dp/B07L5YRYF4/ref=cm_sw_r_cp_apa_glt_fabc_3NMBW2F3WRXN8GV6SK9S
Message posted on 07 Jun 2021 01:47 PM
Nice one,
Thanks both for the advice
Message posted on 07 Jun 2021 03:37 PM
@symun wrote:@cookiemonsteruk Is having the powerline adapters better than having an access point plugged in to my main router via ethernet? Or is it essentially the same?
@symun A direct ethernet cable will always provide the best performance, and is superior to Powerline tech. Powerline is the next best thing ahead of relying on WiFi if you can't run a proper ethernet cable.
1) Ethernet - Best
2) Ethernet - Better
3) WiFi - Hit and miss/Usable/convenient
As you have (smartly) already run a cable, use that and get an access point as @TimmyBGood suggested 🙂🤓
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Message posted on 07 Jun 2021 03:59 PM
If you want seemless connection up there then the best option is a Sky booster. Any other AP may not for whatever incompatability reason make your devices roam over to it properly.
