Discussion topic: 3 green lights no Internet issue
Message posted on 21 Mar 2022 11:02 PM
So it was working fine all day then suddenly lost connection. I have tried everything resetting the router, hard reset etc, all light cone back on green and all looks fine but no internet. Not even hard wired to the sky main box which is still saying we sre not connected. It is like it is stuck in some sort if loop. Its driving me bonkers and have pretty much reset everything. Any ideas, my wife has a really important call tomorrow and I cant seem to get round this issue at all. Need urgent help really !I do wonder if it is a router issue ? Help desperate.con
Message posted on 22 Mar 2022 06:47 AM
Re: 3 green lights no Internet issue
@joanna+kennedy Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 22 Mar 2022 08:46 AM
@joanna+kennedy I have experienced the same loss of service where there are no obvious errors or faults showing.
The cause for me had been sky's dns service failing,
The fix was to use an alternative dns, (google 8.8.8.8) cloudflare 1.1.1.1) are a couple of options.
Any dns changes are per client device,
If your issues are not dns related, it's easy to roll back to sky's dns service & you can rule out any dns problems.
Tom...
BELIEVE =accept that (something) is true, especially without proof.
BETTER = of a higher standard, or more suitable, pleasing, or effective than other things or people:
Sky Q & 2 mini’s
SR203 router. > Replaced with ASUS XT9’s with a TP-Link TD-W9970 modem
Sky superfast 80/20 :sort of, 63-75/15. Devolo 1200 wifi > Replaced with cat 6
Sony KDAF8 65 oled.
Message posted on 22 Mar 2022 09:49 AM
@joanna+kennedyIf you are testing to see if this is a DNS related issue this can be done by device to see if this is infact what is going on. Following the directions of @TomThumb5ive
