Discussion topic: Sky Box Sets
This message was authored by Oracledave This message was authored by: Oracledave
Sky Box Sets
The Sky Box sets channel show just 20 series (trending this week). How do I access all the other Box Sets (500 ?)
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky Box Sets
You would need to download them. via On Demand.
This message was authored by Doc5907 This message was authored by: Doc5907
Re: Sky Box Sets
In the on Demand menu under Sky Box Sets there now is only a small number of options when there used to be many more. I think this is what the OP is referring to.
Sky Q 1TB UHD
LG TV
Sky Mobile
BT Broadband
Re: Sky Box Sets
@Oracledave
I had the same issue as you but a reboot of my box solved it and restored the full selection.
To reboot your Q box.
Press Standby on your Sky Q remote and then switch off and unplug at the mains.
Wait a few minutes and then switch your Sky Q box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait a few seconds before you press Home on your Sky Q remote which should change the light to green and home screen should appear.
Sky Q 1TB UHD
LG TV
Sky Mobile
BT Broadband
On average, new discussions are replied to by our users within 5 hours
