20 May 2023 05:54 PM
How to get a sky landline phone / connection. I do have sky broadband and tv and talk. Any idea?
20 May 2023 06:14 PM - last edited: 20 May 2023 06:15 PM
If you have Sky broadband then you will probably have Sky Talk and if you upgraded or change to sky recently it will likely be Sky Talk with Internet Calls - https://www.sky.com/help/articles/about-internet-calls
If your router has a voice light on it and it's green you just need to plug a standard phone handset into the phone port on back of router
Posted by a Superuser, not a Sky employee. Find out more@Pankaj+KayHave you already signed up and been connected to Sky services or are you looking to join Sky?
21 May 2023 10:15 AM
Posted by a Superuser, not a Sky employee. Find out moreNote that Sky does not have an own-brand telephone handset (basically of all the ISPs only BT does that). Any mainstream analogue corded handset or DECT base station should be compatible with either Sky Talk from a phone wall socket or Sky Talk Internet Calls from the socket on the router.
On average, new discussions are replied to by our users within 80 minutes
