Discussion topic: a womans voice comes on when I turn my TV on and when I change the sound I want to delete it
This message was authored by SHARP-D8 This message was authored by: SHARP-D8
When I  tirn on a womans vioice speaks and talks while I am looking for programs and when I alter the sound I want to delete it
SHARP-D8
Re: a womans voice comes on when I turn my TV on and when I change the sound I want to delete it
you are not answering my query
Have you got audio description turned on, press the help button and then the right arrow button to off then press Sky.
@SHARP-D8  You need to be aware this is a customer helps customer forum and replies from fellow customers are not immediate.
@SHARP-D8
I'd also suggest checking to see if you've inadvertently activated an Accessibility setting on your television set (you'd probably need to use the TVs own remote to access its settings).
This message was authored by Mark-Br This message was authored by: Mark-Br
To turn Audio Desxription on/off follow these steps, taken from this site.
Sky+
  • Press the Services button on your Sky+ remote.
  • Press the left or right arrow to toggle audio description On or Off, then press Select to save the setting.
  • Press Back Up to close the menu.
If you recorded a show with AD on Sky+, it’ll be included and can’t be turned off in that recording.
Mark
Community Manager
This message was authored by SKY1992bf This message was authored by: SKY1992bf
@TimmyBGood wrote:
@SHARP-D8
@SHARP-D8  I think @TimmyBGood is correct in that it's a setting on your tv not your sky box that needs changing especially if it's speaking when changing volume as I don't think sky boxes speak when changing volume
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
On average, new discussions are replied to by our users within 100 minutes
