3
Discussion topic: Sky tv/remote
This message was authored by Lilyladles This message was authored by: Lilyladles
Sky tv/remote
Hi, my Sky remote doesn't control my Sky+ box (other than volume) and the screen shows the wrong time. I've tried changing the remote batteries and pressing the remote numbers as per the help instructions but this doesn't help. Sky bot's recorded messages aren't helping. I'm stuck.
This message was authored by Annie+UK This message was authored by: Annie+UK Answer
Re: Sky tv/remote
Have you tried turning off your Sky box at the plug for at least 5 minutes?
Re: Sky tv/remote
Lilyladles
Re: Sky tv/remote
Thanks, did that. Now everything seems normal apart from not being able to turn the tv on or off. I have to use the buttons underneath the TV screen.
Re: Sky tv/remote
Sounds like your remote lost its programming when you change the batteries, try reprogramming it
Program your remote
On average, new discussions are replied to by our users within 100 minutes
