06 May 2023 01:16 PM
My Sky+HD box was working fine last night but this AM after Power-up, nothing. I know the screen functions because I can see Freeview etc. I tried powering-Off at the wall, waiting 5 minutes and restarting but no difference.
06 May 2023 02:43 PM
No. So, I just went to try such but, immediately on powering-up, the screen displayed the Sky Intro ! Presumably, I'm out of the woods ? Bloomin' strange though - I'd like to thank and the others for the Help and will now attempt [ gulp ] to mark this Issue as answered.
06 May 2023 01:19 PM
Posted by a Superuser, not a Sky employee. Find out moreCan you clarify unresponsive?
Have you tried controlling the box with the buttons on the top of the box?
06 May 2023 01:33 PM
Hello and thanks for your interest. Once the TV and box are powered on, the screen is blank [ grey ] except for the word Sky in the top left corner - such being provided by my TV AV-input setting, yes ?
Whatever I select on my Remote doesn't shift it nor did the coupla buttons that I tried on top of the Sky+HD box itself and, as I mentioned, I also tried a re-Boot.
PS: I'm new to these Fora and had no notion of Tagging you, sorry.
06 May 2023 01:41 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried pressing the big Sky button on your remote as it sounds like it is your TV that is the issue as it is not displaying the picture from your box.
06 May 2023 01:52 PM
Please note that I mis-understood the purpose of the Mark-as-Answer button - my problem is far from being resolved. Further, I just tried that Tag-thing and obviously don't understand that either - sorry !
I know that the screen is working [ it displays "Sky" and I can watch Freeview ] but I tried the larger Sky button on the Remote several times to no avail.
06 May 2023 01:55 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried pressing the TV button on the Sky remote and then the help and keep pressing the help button one as it should the cycle through all the available channels. If it finds the Sky one press the Sky button.
06 May 2023 02:02 PM
Posted by a Superuser, not a Sky employee. Find out more@Motspur basics first: when you bring the box out of standby, does the power LED on the front panel change from amber to green (or red to green)?
06 May 2023 02:35 PM
Yes. I also watch carefully to see that subsequent Instructions are acknowledged by an adjacent light-flash on the box-front. Plus, it occurred to me just now to check the cables and they're all firmly seated.
06 May 2023 02:45 PM
Posted by a Superuser, not a Sky employee. Find out moreSounds like a problem with the HDMI output (I assume the box is connected via HDMI cable to your TV). Try a different HDMI port on your TV, Also try disconnecting the HDMI cable at both ends, swapping the ends over and reconnecting it (make sure the box and TV are both in standby when you do it). If you still have no joy, try a replacement HDMI cable.
06 May 2023 02:50 PM
Thanks for that Mark but, per my Posting of a few minutes ago, the problem seems to have resolved itself but thanks to you and the rest.
On average, new discussions are replied to by our users within 100 minutes
