05 May 2023 11:40 PM
I have a wire connected to the satellite and has been drilled through the wall into my living room. Make the room look hideous. Anyway I can get rid of it?
06 May 2023 08:04 AM
Posted by a Superuser, not a Sky employee. Find out moreYou mean a cable from the dish? If it's not connected to a Sky TV box, you can remove it, if you wish. If there's anything connected to the dish elsewhere, I'd suggest unplugging it from the mains before you remove the cable.
06 May 2023 10:10 AM
@Yas1120 wrote:I have a wire connected to the satellite and has been drilled through the wall into my living room. Make the room look hideous. Anyway I can get rid of it?
Is it attached to your Sky box?
06 May 2023 10:12 AM
The dish is on the garden side. Living is at the front of the side. The wire is connected to the dish, goes over my roof to reach the front to connect to the living room sky box.
06 May 2023 10:14 AM
Posted by a Superuser, not a Sky employee. Find out moreYou'll lose your Sky tv service if you remove the cable, in that case.
On average, new discussions are replied to by our users within 100 minutes
