Discussion topic: My father has no sky signal
This message was authored by Claire874 This message was authored by: Claire874
My father has no sky signal since this morning.... He cant get it to work at all.
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: My father has no sky signal
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and other not)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Claire874
He's tried everything..... Knocking it off for a bit and turning it back on and still no channels coming up.
This message was authored by Mark39 This message was authored by: Mark39
Can you clarify:
No signal?
Or no satellite signal?
This message was authored by Andymac1 This message was authored by: Andymac1
Yes me also in blackpool
This message was authored by oj01 This message was authored by: oj01
Assuming it's 'No Satellite Signal', given the storms overnight, the dish having moved is the most likely reason. As mentioned above, Sky will no longer come out and support Sky+HD systems so you would need to call a local satellite company.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Staying on Sky+HD
Same answer as the post above this one.
Staying on Sky+HD
On average, new discussions are replied to by our users within 100 minutes
