Discussion topic: Sky + hd box slow to (and sometimes doesn't) respond.
This message was authored by keithinscotland This message was authored by: keithinscotland
Slow to load tv guide
Slow (can be a up to 2 minutes) to load planner
Picture freezes
Can take full minute to change channel
On playing a recording from planner, sometimes plays but can stick and then restart, sometimes get error message saying technical problem with this channel
I have tried rebuild but problem remains. Not yet tried reset as don't want to lose existing planner recordings.
Also tried swapping box to other room but same problem so unlikely to be cabling issue
Any suggestions ?
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Sky + hd box slow to (and sometimes doesn't) respond.
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
keithinscotland
Thanks for reply
Rebuild already done per original post
Signal strengths and qualities are both good
Sounds like the Hard Drive might be on its way out if ALL four bars (signal/strength x2) are nearly all white 😞
keithinscotland
Hard drive failure were not the words i wanted to see !!
I can access the individual recordings on the planner but when attempting to play them they only go for about 30 seconds and then stick/play/stick. Recordings scheduled did not work.
Thanks for reply
On average, new discussions are replied to by our users within 100 minutes
