Discussion topic: Help to see purchased movies
This message was authored by Skippy1964 This message was authored by: Skippy1964
Hi I have purchased 2 movies and can't see either, I go to my purchases in recordings and get this message, To see your purchases, you must be connected to broadband. Please check your settings.
I have wireless internet connection so does that mean I have wasted my money?
cheers Skip
Re: Help to see purchased movies
What device are you trying to view your purchases on ?
This message was authored by mike+simmonds This message was authored by: mike+simmonds
Hi @Skippy1964
Do you have Sky Q ? Wifi is fine if that's what you have - but it sounds like your box doesn't think it's connected to your wifi
Have a look in your Sky box on-screen menu and see what's showing for your connection in setup / network. If you don't have a tick - follow the prompts.
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by JamJar83 This message was authored by: JamJar83
I have the same issue. Did you find a solution?
Same question to you @JamJar83
I tried resetting my Q box, re-establishing connection to router etc... but nothing worked.
Then about an hour later (24 hours after we noticed the problem) the issue resolved itself! 🤷🏻‍♂️
This is an issue at Sky's end today as there are posts from others who are having the same issue.
This message was authored by BlythGav This message was authored by: BlythGav
I'm having the exact same issue today on my sky Q 2tb box, box is connected via LAN cable and I can download other movies etc but can't connect to purchases
This message was authored by jepearson This message was authored by: jepearson
Reset settings worked for me.
hover on settings, 001 select, choose reset then reset settings. Restart box, re-pair remote and now it works.
