24 Feb 2024 07:37 PM
i have had problems with our wifi for a while now... so it was sergested to me to connect the router to the skyq box via the ethernet cable - however when i go to settings and try to add this, it comes up with a msg stating that theres is no connection and i have to check my router settings - can someone help me with this please as it should be simple plug in the cable and it should all be set.
24 Feb 2024 07:40 PM
Hi @pete_ashton
First carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
If you have no mini boxes as soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Hi @pete_ashton
24 Feb 2024 09:12 PM
Thank you @oldfella for responding.
i was trying what you said, and i was doing it i was talking to a sky q expert from sky, he asked me to go into system reports ( sky get access to that, customers dont ) it showed up that there was a problem with my router and skyq mini - new devices are being sent out this week.. hopefully this will resolve all the issues i have been experiencing
