Discussion topic: Supported living accommodation upgrading to sky Q
This message was authored by jan222 This message was authored by: jan222
My mother is in a retirement living home and they have all had sky in the past.
Now some have upgraded to sky Q and my mother is due to do the same tomorrow.
Sky Q doesnt seem to be working however.
The manager says the whole system needs upgrading to support sky Q and they may not do it.
Is this true or is it a simple plug in and switch over?
If it isn't going to work I obviously need to cancel the sky Q
Thank you
This message was authored by Quoman7 This message was authored by: Quoman7
Re: Supported living accommodation upgrading to sky Q
Thank you
Hi @jan222 Yes the communal system would need to support SKY Q, if the Manager is not willing to upgrade then SKYQ will not work, I cannot understand how other tennants have SKYQ installed and it isn't working?
Unless some tennants can access the system and others are not cabled in?
This message was authored by Laing1 This message was authored by: Laing1
Thank you
@jan222 So are you saying those with Sky Q can't receive TV now ? or can they get it ?
If no one can get Sky Q then it may be as @Quoman7 says but
If others can get Sky Q  then it may be that Sky have provided a Unitron dCSS-422 Sky Q Plug - In adaptor. Which can work on older systems to make them compatible . It would need a Sky MDU trained engineer to come out and fit this apdapter to the communual system you would need to make sure it's a MDU trained engineer that has been assigned for your mothers installation and if they say they cannot install Sky Q or it won't work they should leave your mum with her current older Sky boxes in a working order
Is there any reason your mother is wanting to change to Sky Q ?
