25 Feb 2024 12:45 PM
No network connection
25 Feb 2024 12:57 PM
Hi @James1236
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
