Discussion topic: Skybox not working
This message was authored by Ze3 This message was authored by: Ze3
Skybox not working
Hi
l have a Sky Q box 1 upstairs 1 downstairs.
Upstairs Sky box not working tried rebooting still not working. What to do next.
Re: Skybox not working
@Ze3 wrote:
Hi
Hi @Ze3
Reboot the mini as above.
