05 Mar 2024 10:38 AM
Hi
l have a Sky Q box 1 upstairs 1 downstairs.
Upstairs Sky box not working tried rebooting still not working. What to do next.
05 Mar 2024 10:58 AM
@Ze3 wrote:
Hi
Hi @Ze3
Reboot the mini as above.
