20 Sep 2023 05:14 PM
Sky q box won't connect to Internet??? Fed up now!!
20 Sep 2023 05:17 PM
Assume this is is your main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
20 Sep 2023 05:24 PM
Tried this so many times now with same ending, unable, and yes I've restarted both box and router numerous times, this is just pointless, gunna leave sky, they are getting worse and worse
20 Sep 2023 05:30 PM
No network connection???????
07 Feb 2024 03:24 PM
Hi, did you manage to find a solution we seem to be having the same problem!
