Discussion topic: Sky q box will not connect/find wifi
This message was authored by Bezj This message was authored by: Bezj
Hi. Just had ultra fast plus installed. Q box will not connect to the router.
Re: Sky q box will not connect/find wifi
Hi @Bezj
If on Sky Broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
