Discussion topic: Sky Q mini box connectivity
This message was authored by HSO27 This message was authored by: HSO27
We have Sky Q and a couple of mini boxes, but the TV in the kitchen is constantly freezing the picture to the point where it is just not viewable, the others are upstairs and they work OK.  Any thoughts?  Thanks
This message was authored by Laing1 This message was authored by: Laing1
Re: Sky Q mini box connectivity
@HSO27 Have you tried rebooting your main Q box ie
then reboot the mini box
the kitchen may also be problematic with all the electrical equipment that is in there disrupting the signal
Hi @HSO27
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the minis.
Start with the one nearest to the main Q box or if on Sky broadband the one nearest to the Sky router if nearer than the main Q box.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.  When you carry out the network reset on the second mini use the nearest Q device for WPS (Main box, Sky router or first connected mini)
HSO27
Thanks worth checking out
HSO27
My thanks for all the advice and guidance you have provided,as one of you kindly suggested I contacted Sky on Friday evening.  They sent an engineer round Saturday afternoon, he rebuilt the entire mesh network we have, re configured a few things and installed a booster.  Since them all working well - fingers crossed.
Thanks again
