25 Feb 2024 11:10 AM
Sky Q is constantly freezing, reacts very slowly to remote instructions, screen shows technical fault when channel changed. Sky guys have been out and swapped out everything but the Sky Q box. SCREEN PIXILATION sorted now but everything else isn't.
25 Feb 2024 11:17 AM
hi @craig1504
Assume you have tried a Reset Settings in the Q box hidden menu.
25 Feb 2024 12:27 PM
Did all that with Sky previously. Nothing worked. New Sky Q box on the way.
