17 Jan 2024 05:08 PM
Just installed new Panasonic TV - Model TX-65MX600B. Model is not listed to pair with SkyQ remote and none of the standard options work either. Any advice to help pair and use the volume control?
17 Jan 2024 05:13 PM
Hi @Jay661
When you press 1 & 3 together onthe remote you must make sure that you are pointing your remote at the Q box (not the TV).
Try completly resetting your mini Bluetooth remote again.
One of the Panasonic options should work.
