28 Sep 2023 10:04 AM
Hi, I'm not able to access recordings on my main Q box with a message that says the service is currently unavailable, and when I switch the box on I get a message that says there's a problem with the Hard Disk Drive
28 Sep 2023 10:10 AM
@Chrish26 wrote:Hi, I'm not able to access recordings on my main Q box with a message that says the service is currently unavailable, and when I switch the box on I get a message that says there's a problem with the Hard Disk Drive
That's usually a sign that the hard drive is failing. Turn the box off at the wall for a minute then power it back on and see if helps. It's probably likely that you'll need a replacement box though so you'll need to ring Sky and request one. You'll lose all your recordings I'm afraid.
06 Feb 2024 07:09 PM
Tried this but has not worked
06 Feb 2024 07:17 PM
Posted by a Superuser, not a Sky employee. Find out morePlease see the guide on this article and follow instructions
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
