28 Jan 2024 04:32 AM
I have recently switched to Sky Q from Sky Plus and would like to know which audio setting is more suitable or more similar to the sound i was getting on the Sky Plus ?
28 Jan 2024 07:03 AM - last edited: 28 Jan 2024 07:04 AM
Hi @AM9
It is a long tome since I had SKY Plus so I can't remember if it had the option for both - I am pretty certain SKY HD had both.
Even if you only had the equivalent of Normal it really depends on what you are listening through and it's capabilities.
What are you listening through - is it a TV or a Sound bar or an AV Amp ?
Can it process Dolby Digital ?
With Dolby Digital you will get 5.1 Surround Sound from some/many sources although some such as ITV only use 2.0 channel Stereo but you don;t get DD on SD channels
Whilst some TVs and a few Sound Bars can process Dolby Digital they don't always sound better when they get a 5.1 signal - it can depend on how many speakers they have where the speakers are situated and what walls / furnishings are around them
I have a been a big advocate of Surround sound since the mid 90s & really think it can enhance the experience but I have always had a separate AV amp and discrete speakers.
At the end of the day it is what sounds best for you.
28 Jan 2024 12:12 PM
No soundbars just have the sound come from a LG tv but when it's on normal it sounds significantly louder i thought it would be the opposite
28 Jan 2024 12:40 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @AM9 Normal (PCM) should be louder.
