2
Discussion topic: My sky remote is not working, I have changed the batteries and tested them in a seperate remote
This message was authored by Mayflower01 This message was authored by: Mayflower01
My sky remote is not working. I have changed the batteries and tested them in a different remote
It seems as though the box is not recognising it.
I can use sky if I programme the Samsung remote
I can turn the sky box on and it shows sk on the tv,
This message was authored by Laing1 This message was authored by: Laing1 Answer
Re: My sky remote is not working, I have changed the batteries and tested them in a seperate remote
@Mayflower01 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
then
Mayflower01
Thankyou, I did the remote reset and it worked
