07 Feb 2024 02:04 PM
My sky remote is not working. I have changed the batteries and tested them in a different remote
It seems as though the box is not recognising it.
I can use sky if I programme the Samsung remote
I can turn the sky box on and it shows sk on the tv,
07 Feb 2024 02:49 PM
@Mayflower01 Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
then
07 Feb 2024 05:27 PM
Thankyou, I did the remote reset and it worked
