Discussion topic: I can receive no TV chanells. A message appears on screen saying there is a technical fault.
This message was authored by Dav7 This message was authored by: Dav7
When I turn on my Sky Q box a message appears saying there ids a technical fault, so I cannot receive any channels. How can this please be fixed?
This message was authored by MightyQuinn This message was authored by: MightyQuinn
Re: I can receive no TV chanells. A message appears on screen saying there is a technical fault.
Hi @Dav7   Have you tried a power reboot?
This message was authored by silibaziso This message was authored by: silibaziso
I was watching Indian channel when a message appeared saying technical fault on the channel. I tried bbc1,2 and 3 and same message appears. I switched off everything and still same message appears. Tried watching recordings but still nothing happens. My main box in next room is working fine. I can see all the recordings but when I press play it does not and screen goes blank.
Hi @silibaziso
@Dav7
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
This message was authored by Aly48 This message was authored by: Aly48
My sky q is saying there is a technical fault with this channel
This message was authored by Invisiblename This message was authored by: Invisiblename
Use the link in the post above yours
I am just another Sky customer!
