Discussion topic: Mini box
This message was authored by Sarah153 This message was authored by: Sarah153
Mini box
My sky mini box is not working. Saying no connection.
l have rebooted main box a few times and even contacted my broadband provider who confirmed no issues there
Re: Mini box
Hi @Sarah153
Reboot the mini as above.
