Discussion topic: Hi, my Sky Q box is not receiving the BBC1 channel without a lot of interference. This happens on bo
This message was authored by BarbaraHO This message was authored by: BarbaraHO
Hi, my Sky Q box is not receiving the BBC1 channel. This also happens on both the mini Q boxes
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Hi, my Sky Q box is not receiving the BBC1 channel without a lot of interference. This happens o
@BarbaraHO
Any error message displayed at the top of the screen? Could be your dish is out of alignment.
▪️I AM NOT A SKY EMPLOYEE ▪️
BarbaraHO
There is no error message.
How can the dish be realigned?
@BarbaraHO
If that is the issue it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company but otherwise it'll need an engineer to check it.
BarbaraHO
It's a private house. Is that something a sky engineer could/should do?
@BarbaraHO
Yes it is as long as you have your own dish.
Have you tried a reboot of your main box yet? Do the main box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
BarbaraHO
I have tried all that several times. It hasn't worked.
