Discussion topic: SKYQ remote code for Pioneer VS-930
This message was authored by Raj+Pate This message was authored by: Raj+Pate
Does anybody have the SkyQ remote code for a Pioneer VSX-930 amplifier?
I've tried all the ones from the help and guides but no luck.
Thanks in advance.
Re: SKYQ remote code for Pioneer VS-930
Thanks in advance.
Hi @Raj+Pate
If this is for a Q remote (Bluetooth with microphone button) then these do not use codes and are paired by Brand and Model
This message was authored by PandJ2020 This message was authored by: PandJ2020
The codes are generally for TV's, although some soundbar/amps may be there or work.
Instead, you may be able to sync the remote the TV and use HDMI-CEC to control the Amp volume.
I am just another Sky customer and my views are my own
Raj+Pate
I have both versions of remote controls and they were working until having to do a hard reset of my SkyQ box last month.
Raj+Pate
Fixed it, I successfully paired up to my LG TV first and then it asked me to pair to the amplifier so I picked Pioneer and then selected it and bingo it works on the Bluetooth remote for sure.
