Discussion topic: 10Bit settings Sony A95L tv with Sony HT-A7000
This message was authored by ZainUAH This message was authored by: ZainUAH
Need some help please.
I have a Sony XR65A95L connected to sony ht-a7000 soundbar connected via eARC. The sky q is plugged into the soundbar, the soundbar setting allows upto 8k on hdmi.
For some reason I cannot get 10bit settings on sky, only allows me to do 8bit
All cables are hdmi 2.1 48gbs
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: 10Bit settings Sony A95L tv with Sony HT-A7000
Does it work bypassing the soundbar?
I am just another Sky customer and my views are my own
This message was authored by MightyQuinn This message was authored by: MightyQuinn
Hi @ZainUAH   I don't have that soundbar, but have you set the soundbar input to enhanced as well as the ARC HDMI setting on the TV?
ZainUAH
Tried that same issue
It helps if you mention or quote who you are replying to...?
ZainUAH
Pand
I tried bypassing soundbar still same issue
@ZainUAH wrote:
Pand
Hi @ZainUAH   So you have set the Sky Q (or ARC) TV HDMI input to Enhanced? Also what is the length of the HDMI cable?
Hi @ZainUAH
How long are your HDMI cables?
ZainUAH
Yes I have set it to enchanced, hdmi length is 2m
This message was authored by Chodley This message was authored by: Chodley
So the soundbar isn't relevant to the question, it has the same problem direct to the TV? Just checking my understanding.
ZainUAH
Direct to tv is the same issue
And enhanced colour or whatever Sony call it is on for the right hdmi inputs... weird... tried multiple cables?
ZainUAH
Enchanced colour setting on
Tried with original sky cable as well purchasing another cable hdmi 2.1 48gbs
Have you tried a settings reset in the installer menu on the Q?
ZainUAH
Where do I find the settings reset?
