Discussion topic: Q box isn’t connecting to sky Wi-Fi
This message was authored by GillianT0309 This message was authored by: GillianT0309
I've reset the Q box and the router and run a check on my broadband. Other devices are connecting fine to my Wi-Fi but I cannot get the Q box to. Any advice on what else I can do much appreciated.
Re: Q box isn’t connecting to sky Wi-Fi
Hi @GillianT0309
Have you carried out a Network reset on your Q box?
GillianT0309
Yep I have
This message was authored by Chodley This message was authored by: Chodley
Try the steps in post 7 here
https://helpforum.sky.com/t5/Sky-Q/Sky-q-box-not-linking-with-Wi-Fi/m-p/4504698#M618552
and also take a look at the link in post 8
