201
Discussion topic: Sky Go not opening on Android (Error 20190000)
This message was authored by Unhappy+Lee This message was authored by: Unhappy+Lee
[-20190000] error message when trying to open sky go app
There was a problen opening the app, Error [-20190000] please restart the app and try again. Below message says Retry but that doesn't work.
This message was authored by D3V0X This message was authored by: D3V0X
Re: Sky Go not opening on Android (Error 20190000)
Hello all,
in Germany, some customers also had a similar error.
It turned out that Android System Web View was not up to date.
After updating Android System Web View via Google Play and restarting the phone/tablet, Sky Go could be started again.
Maybe it will help some of you too.
Best regards from Sky Deutschland. 🙂
This message was authored by TJ2468 This message was authored by: TJ2468
Looks like an uninstall of the System Android Webview and a reinstall did the trick for me
This message was authored by Flats2514 This message was authored by: Flats2514
Where is the system web view? Is this part of the settings already?
This message was authored by DanBase This message was authored by: DanBase
Found how to update the webview on Samsung Tablet (instructions below), and have updated the webview, but the error is still appearing. Uninstalled the Sky Go app again, reinstalled etc and still the error appears! Thank you for the help, but any other suggestions to get the app working?
1. Open Settings. Go to Applications.
2. Select Chrome. Disable Chrome.
3. Open Play Store and search for Android System WebView. You should now be able to update it.
4. After updating, open Settings, choose Applications, Chrome and reactivate Chrome again.
5. Restart.
This message was authored by Anonymous This message was authored by: Anonymous
Hi,
My sky go isn't loading keep getting getting error message There was a problem starting the app. Error [-20190000]. Please restart the app and try again. I've tried deleting the app and reinstalling, nothing seems to be working. Any advice?
This message was authored by Gazh83 This message was authored by: Gazh83
Sky go app on android
My sky go app has suddenly stopped working it says 'there was a problem starting the app error (20190000) Please help?
Re: Sky go app not working on fire tablet
I have same issue error (20190000) on my android device, how did you sort it please?
This message was authored by Kirsty+S27 This message was authored by: Kirsty+S27
Posted by a Sky employee
Hi all,
We have raised this issue to the support teams to investigate. They have requested further information. Please can those having this issue please complete the following:
  1. Which make/model of Android device do you use?
  2. Which version of the Android operating system is installed?
  3. On the device that you are seeing this issue, do you have any other Sky apps installed (Sky Kids, Sky Sports, Sky News or others)? If so, which ones do you have?
  4. If possible, could you delete these other apps and try Sky Go to see if the issue still occurs? (Note: try uninstalling Sky Kids first, then retrying Go before uninstalling others)
  5. If you are still experiencing issues, search for ‘Accounts’, or ‘Passwords and accounts’, or similar. Different phones label this differently, depending on the make/model of the phone. (Note: these are Android settings, rather than Sky Go settings). Try deleting all Sky accounts and try Sky Go again.
  6. Do let us know the outcome of these steps… which one fixed the issue for you, or if you still experience issues.
Thank you.
Kirsty
Community Manager
This message was authored by davads This message was authored by: davads
1. Samsung Galaxy S10
2. Android Version 12
3. I only have My Sky
4. Have uninstalled the above, still getting the same error on running Sky Go
5. Removed Sky Go account but still having the error
6. In summary, still having the error on running Sky Go.
Appreciate the reply, though, Kirsty. Hope some solution comes to light.
Huawei p30 pro
Android 12
Only have skygo
Have removed app and installed again but still not working
Samsung Galaxy Tab A6
Android 8.1.0
Only Sky Go
Removed and reinstalled multiple times and error still appearing
Thank you all for providing the information the team require. I have passed this on for investigation.
Thanks again.
Kirsty
Community Manager
This message was authored by Jenks. This message was authored by: Jenks.
I'm having the same problem (Samsung phone) and have tried all the reinstall/restarr steps - does anyone have the solution? App is working fine on other devices in the house.
This message was authored by Craig+Anthony1 This message was authored by: Craig+Anthony1
Error code 2019 0000 sky go
Hi all,
Seen a lot of people on here with the error code 2019 0000 on the sky go app. How was this resolved?
On average, new discussions are replied to by our users within 3.6 hours
