Discussion topic: no WiFi coming into house.
This message was authored by Georgie7 This message was authored by: Georgie7
Hi my OPT box LOT is showing red no WiFi coming into house. Have done all checks says it's external problem
Moderator note: Moved from news comments and gave title to cover topic.
This message was authored by daveNOS This message was authored by: daveNOS
Re: no WiFi coming into house.
@Georgie7 You could try running the 'test my connection" in the mysky app(can be run from a smartphone using mobile WiFi)to see if it detects the issue and allows you to book an engineer, if it doesn't you will have to call Sky to report the fault, the forum is mainly customer to customer support so no-one here can help.
-------- Please note i am not a Sky employee ----------
