5
Discussion topic: Ethernet ports
This message was authored by Red+Silence This message was authored by: Red+Silence
Ethernet ports
Good morning..
May I ask how many ethernet ports the current Sky fibre broadband router had please?
Just in Currys and their dummy has only 2. I need 4. There's things on my network tht require a cabled connection.
Thankyou
This message was authored by GD1 This message was authored by: GD1 Answer
Re: Ethernet ports
@Red+Silence  The Sky Q hub has 2 the Sky Broadband hub (this is the latest version) has 4.
Re: Ethernet ports
Red+Silence
Re: Ethernet ports
Thankyou
Re: Ethernet ports
@Red+Silence
Perhaps worth noting that for an FTTP broadband service one of the four ethernet ports on the Sky Broadband Hub is occupied by the WAN connection to the ONT ('fibre modem') so only three are available for other use.
This message was authored by Louise711 This message was authored by: Louise711
Re: Ethernet ports
Can I order a router with 4 ports?
Re: Ethernet ports
@Louise711
Sky should no longer be offering Q Hubs to new users, so the default is now a four port Broadband Hub.  They may however still charge to go from one to the other, in which case buying a small ethernet switch is cheaper.
