15 Jan 2024 06:39 AM
hi everyone,
looking to get wifi into garden office (30 metres)
Will connect ethernet cable (exterior grade) to sky hub box
Connect ethernet cable into a wireless access point like this
Couple of questions.
The wireless access point, I've also seen this one here, is this better? Seems cheaper + more reviews
Which port on the sky hub SR203 should the outgoing ethernet cable (to the garden office) be plugged into?
thanks so much
15 Jan 2024 06:46 AM
The WAX202 is a wifi 6 router/access point and should give you faster wifi. However both should work fine. If you have fttp full fibre then use any ethernet lan port ie 1-3 (the 4th lan port will be ethernet to the ont).
