Discussion topic: Full fibre
This message was authored by Michal92 This message was authored by: Michal92
Full fibre
Hi there I stay in a flat on 2nd floor and openreach upgraded the building to full fibre we do have an openreach box on ground floor and they were doing something on each floor I'm assuming cables so each flat got them just in front of their doors in the wall my question is how the engineer will install my gigafast broadband in my flat
Re: Full fibre
@Michal92
Usually with multiple dwelling units openreach will install a fibre optic drop box above each each door
And once ordered will install the fibre optic modem inside on your activation date
If you enter your full postal address below and post the table and notes below after removing your address from the image
Re: Full fibre
@Michal92
P.S. inside the drop box is about 10 metres of thin fibre optic cable so a small  hole will be drilled to bring the fibre optic inside the flat
Michal92
Re: Full fibre
Thx for your answer they did install something inside this panel outside my door
Re: Full fibre
@Michal92
Admittedly i haven't seen one of those before. What does it say on the bt wholesale checker
Michal92
Re: Full fibre
Michal92
Re: Full fibre
The panel was originally there I'm assuming there are other cables inside and openreach put theirs
Re: Full fibre
@Michal92
And the notes under the table.  There is a 1 stage install which does indicate the fibre is already up to your door without any issues so you can place an order if you haven't done so already
Michal92
Re: Full fibre
Thanks for ur answers
Re: Full fibre
@Michal92
Ah, existing conduit.  Sounds straightforward then. Are they still installing on other floors.? Is there any sign of fibre cables coming out?
Michal92
Re: Full fibre
They have finished my building and I was able to upgrade but sky engineer will come and install the gigafast but not until after New Year as they're busy and was wondering how they will do it as I read the ont needs to be installed in my flat etc
Re: Full fibre
@Michal92
With wbc already showing available i would wonder if they directly bring the fibre out from the conduit and into the flat. .  Usually each flat would have a drop box per my photo it may be horses for courses and they feel they can install directly from the conduit. Even If they do add the drop box its straightforward process .
Michal92
Fttp to a flat
 So openreach has installed something like that inside the cupboard in front of my flat(conduit ?) and wondering how they will run Ont box into my flat
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Fttp to a flat
@Michal92
Your two duplicate posts have been removed. You have this one.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Fttp to a flat
I suspect that's a fibre drop cable and an indoor CSP.  An optical pigtail will be spliced inside the white plastic enclosure and go to the ONT, which needs to be adjacent to a power socket.
