12 Dec 2023 09:39 PM
Hi , anyone else having intermittent issues with wifi dropping out ? Sky sent me a new hub but no better . Any ideas what to do next ?
13 Dec 2023 07:20 AM
Mine has been dropping since yesterday afternoon. Anything on mobile devices will not open at all, tv just about running.
My download speed on router is running around 15Mbps and my upload speed at 0.1Mbps!
Appalling!
13 Dec 2023 07:30 AM
Posted by a Superuser, not a Sky employee. Find out more@radargirl & @Si0505 run the connection test in the My Sky app which will work overca mobike connection if your Sky Broadband is down as that shoukd tell you if there is a known fault affecting your line. If the test can access the hub and it finds a faultvaffecting through put it can offercto book an engineer to check that for you.
If it does neither you will have to contact Sky to report the issue the phone lines are very busy due to thecrecent bad weather and the pre-Christmmas rush but if you post againnafter doingvtgectest above one of the superusers can escalatecyour post to a Sky chat team.
13 Dec 2023 07:39 AM
Have run Sky's & every connection check going and everything tells me it's ok! Takes about 2 minutes to open any page on desktop. Keep getting browser message that 'this page may be having a problem or may have moved', then whirrs for a while and eventually connects.
13 Dec 2023 09:44 AM
Posted by a Sky employeeHi there, radargirl. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
13 Dec 2023 10:05 AM
I have run the check and tells me all Ok when clearly this is not the case
13 Dec 2023 10:57 AM
About 5 minutes after running the checks, and my last post, everything suddenly clicked back to normal! At the current moment I have no problem!
13 Dec 2023 11:04 AM
Posted by a Superuser, not a Sky employee. Find out more@Si0505 then Sky need to check what the problem is I have escalated your post to the team who posted for @radargirl to contact you and send you an invitation to chat. Keep an eye on the forum as they will add a brightly coloured chat icon.
13 Dec 2023 12:46 PM
Posted by a Sky employeeThanks for escalating this. We’ve sent @Si0505 an invite to chat.
