Discussion topic: WiFi is very unstable
This message was authored by Debbie401 This message was authored by: Debbie401
My wifi is terrible and continuously drops on all devices unless connected via an Ethernet cable. I'm very disappointed, my son has lost all his university work
Re: WiFi is very unstable
@Debbie401 wifi can be a problem and for any crtical work ethernet is a far better connection. However you can do things to improve WiFi . Make surecyour Sky hub is not on the floor or worse under other kit. Wifi signals are like light so pkacectge hub on a table or shelf so thecsignals are not blocked by radiators and other kit. A lot depends on the layout and type of construction of your home and how many neighbour's networks are within range as interference is a very common issue. This link explains more Sky Help - Slow wifi
Hopefully your son saved a local copy of his eork but I think  everyone has lost something before they learnt that lesson
