Discussion topic: Wi-Fi / Broad band
This message was authored by Michelle788 This message was authored by: Michelle788
Wi-Fi / Broad band
My connection keep dropping and I’m unable to connect to Teams using my Wi-Fi/ broadband. It keeps saying no connection and I have to keep rebooting and restarting my laptop
Re: Wi-Fi / Broad band
@Michelle788 check the lights on your Sky hub as they can tell you what is wrong see https://www.sky.com/help/articles/hub-lights-explained-start
Hi @Michelle788
Please post your router stats
I am NOT a Sky Employee
Michelle788
Thanks for your reply, all lights are on a green. My internet keeps dropping when I'm on my laptop since I applied McAfee !
This message was authored by cuke This message was authored by: cuke
What happens when you uninstall Mcafee? I've experienced this before on a customers laptop and removing the antivirus resolved it.
Michelle788
I have paid for the application and it is clearing up my laptop, it's for virus protection.
@Michelle788
Sorry but if its suddenly started happening as soon as you installed Mcafee then it may be that causing it.
If you post your stats like a requested before we can check to make sure it isnt your Sky connection.
