17 Nov 2023 12:14 AM
Cambridgeshire region. Dropped at 23:08 on Nov 16. Anyone else?
Superfibre. Latest hub model from 3 months ago.
Wan connection dropped. Vdsl2 still up (us=19999, da=64864, from the logs)
Going to Gui > Maintenance I see modern says Disconnected but did show twice type PTM and line speed up and down. Broadband port is all blank. Connection status says "connecting" abd that's it, it's been like that for over 1h now
Rebooting didn't help. Gets back to the exact same state: vdsl2 comes up, but wan connection is down and different get an IP address
Sky says no outage in the area, but I doubt theirv status pages as they weren't accurate in the past either.
17 Nov 2023 12:43 AM
Finally connected ... 1h30 downtime in less than 3 months since signing up.
For the veteran Sky broadband customers: How often does this happen at Sky?
17 Nov 2023 01:53 AM
Mine cut out about 20 minutes after midnight today. Internet light went yellow and then off. It returned about 10-15mins later.
Internet cut out yesterday as well about 1 hour after midnight. Light stayed amber during this time. Downtime was longer - about 30-40mins or so.
I've been with Sky for nearly a decade and it's been rock-solid stable almost all of the time. I've not had many issues with my broadband.
Downtimes happen occasionally. It shouldn't be a common occurrence.
17 Nov 2023 12:07 PM
Posted by a Superuser, not a Sky employee. Find out more@WestleyZero your brief outage was probably due to Sky making an upgrade or maintaining the backhaul equipment which would explain why your hub remained connected to the cabinet. Sky, Openreach and other network operators use the hours between midnight and 5am for maintanance to cause the minimum disruption.
In answer to the question about how often does this happens you can go years without any noticeable disruption then have regular drops every night for weeks it is totally unpredictable.
