Discussion topic: Transferring old SSID and password to replacement router
This message was authored by jetandy This message was authored by: jetandy
In theory I'm thinking this should work, but has anyone done it?
I'm considering upgrading to fibre but the thought of re doing the setup on all of my Alexa switches and lights etc is daunting...
So I thought that if I just changed the SSID and password in the new router to the same as the old...everything should connect....right?
This message was authored by Laing1 This message was authored by: Laing1
Re: Transferring old SSID and password to replacement router
@jetandy yep that should work
I did it a few years ago and had a couple of devices i had to reconnect but the old ssid and password wre easy enough to put back into a coupe of devices
This message was authored by mormegil This message was authored by: mormegil
I have done it with the new sky max hub, only device that didn't connect automatically was my tv but the wps buttons worked to reconnect that
all my 2.4ghz devices ring cameras, printers and Alexa connected straight away or after next power cycle without having to re enter any passwords again
