13 Dec 2023 02:21 PM
Recently changed from Ultrafast to Gigafast broadband over a week ago and I have unplugged the ONT etc but download speeds are still the same approx 80Mbps but is advertising as 900 Mbps,with average of 600 ,the upload speed has increased funny enough....
Is there a quick fix to this?Everything is fine bit concerning about the download speed...
Thank you for anyhelp.....ps I am not an expert lol ....
13 Dec 2023 02:27 PM
How are you measuring that? If it's an inherent limit on the device in use, a much faster speed at the Hub can't change it.
13 Dec 2023 02:35 PM
Done speed test via apps on my Firecube which is hardwired to the router.....plus on phone/ tablet just on wi-fi..
Like I say everything is fine I was just presuming that the speeds would automatically increase on the apps etc .....
Even changed the ethernet cables to cat 6.read all the forum chats seems an ongoing issue for some.
Thank you for answering BTW
13 Dec 2023 03:02 PM - last edited: 13 Dec 2023 04:50 PM
I'd note that all generations of the Fire TV Cube (including the 4K) have a 10/100Mbs ethernet chipset, not gigabit ; )
Such devices stream UHD at most, which tops-out at about 30Mbs of bandwidth demand.
Sky Glass and Sky Stream hardware is similarly specified, with WiFi 6 but 'only' 100base-T ethernet.
13 Dec 2023 03:13 PM
Oh right,well thank you for your help.....so a daft question how do I actually check that I'm getting the gigafast speeds that are being advertised?
Again thank you...told you I was no expert lol
13 Dec 2023 03:17 PM - last edited: 13 Dec 2023 04:53 PM
Not daft at all. Only a device with a known gigabit ethernet port (and drivers) cabled to the Hub using a Cat5e or above ethernet connection gives a 'real' result, using something like the fast.com 'test' site.
Trying that here, my PC has just reported 280Mbs and my phone 27Mbs (yes, under a tenth of the wired speed), both accessing the same 300Mbs business FTTP circuit with gigabit ethernet switching and 802.11ac WiFi respectively.
13 Dec 2023 03:19 PM
You a diamond 💎 thank you I will try that and see where it leads.....
Bless ya...
