Discussion topic: Router upgrade
This message was authored by DanMadHouse This message was authored by: DanMadHouse
Router upgrade
I have sky super fast, but guessing we just have too many things connected to it now to maintain any constant good connection. If I'm watching say football on tv it stops every few minutes, if I'm on the PlayStation it's fine but I have that hardwired. We also have a PlayStation portal (connected via WiFi signal) that basically mirror what would be sent to the tv that too is almost unplayable because it just keeps lagging and eventually disconnects. Our speed seems fine (average 55mbps) but I'm guessing the long list of devices in the house dipping in and out is too much for the sky router?
What's my best option? Do sky offer any kind of upgrade that could cope with this type of traffic? If not what router should I buy? I have no idea when it comes to home networking
we have a booster put in upstairs but that doesn't se to help much signal wise
3 TVs, 3 Alexa's, a ring doorbell, 3 mobile phones, a Mac, 2 iPads, a PS5, the PSportal, the washing machine, the whole EV charging system (charging pod, smart meter, the car itself) .... a lot of things to interrupt tv and gaming ultimately
DanMadHouse
Re: Router upgrade
https://amzn.eu/d/iTUOndr
looking at something like the above?
Re: Router upgrade
@DanMadHouse
That would work fine, depends how you want to connect it though. Either bin the Sky router or switch WiFi off on the Sky router and connect the mesh system to it?
I am NOT a Sky Employee
DanMadHouse
Re: Router upgrade
Not sure to be honest. Which ever one worked best? Would this cause issues with our extra sky box upstairs in the bedroom?
Re: Router upgrade
@DanMadHouse
Both would work, removing the Sky hub is technically the 'best' option but that also requires extra work & an external modem if you are not on full fibre.
By extra Sky box do you mean booster?
