08 Mar 2024 12:45 PM
What is going on?
Router Statistics
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 49162 75736 0 9477 273615 00:22:07 LAN Up 24736 17355 0 447545 25582 00:24:01 WLAN (2.4 GHz) Up 5335 2332 0 1404 198 00:22:11 WLAN (5 GHz) Up 66159 40626 0 354294 9529 00:22:09
08 Mar 2024 03:22 PM
Posted by a Superuser, not a Sky employee. Find out more@Paul24444 Give Sky a call on 150 and tell them that you had an engineer out, but your still have outstanding issues with the connection. Listen through the options and stay on the line even after they offer you a text.
08 Mar 2024 01:06 PM
Posted by a Superuser, not a Sky employee. Find out more@Paul24444 Is this you re-starting the router or is it power cycling itself?
08 Mar 2024 01:10 PM
The lights keep going off every so often & we lose connection to the internet, it's gone about 8 times this morning for periods of 5 - 15 mins before returning.
08 Mar 2024 01:27 PM
Posted by a Superuser, not a Sky employee. Find out more@Paul24444 Do all the lights go out on the router or does the power light stay red?
08 Mar 2024 01:29 PM
The power lights stays, all others go out
08 Mar 2024 02:13 PM
Posted by a Superuser, not a Sky employee. Find out more@Paul24444 Sounds like all those issues have not been resolved and you need another engineer out.
08 Mar 2024 02:24 PM
So any idea about how to get another engineer to come out, as if I use the Broadband check on Sky.com or the Sky app, it doesn't flag a problem which it did before when the speed was slow?
