05 Nov 2023 07:43 PM
Hello - I moved over to Sky Broadband a few days ago and my ps4 connects absolutely fine but after playing a game for a few minutes it disconnects. I've tried rebooting, run tests but nothing resolves the issue. Has anyone had these issues and resolved them? Many thanks.
06 Nov 2023 04:15 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @agr76
Please post your router stats
07 Nov 2023 08:40 PM
07 Nov 2023 09:04 PM
Hi @jamesn123
Sorry not sure I posted in the correct place before - please bear with me...my router stats as below:
09 Nov 2023 09:59 AM
Your stats suggest there is no drop in the connection so I suspect the issue is WiFi interference. Can you test via ethernet to see if that solves the issue?
09 Nov 2023 08:27 PM
@jamesn123 Thanks - I'll give that a go and let you know. I never had this issue with TalkTalk - do you think a more powerful router from Sky would help?
13 Nov 2023 06:50 PM
Hello @jamesn123 I've connected via ethernet cable but its still losing the wifi connection. I have read that changing the DNS may solve the issue but I'm reluctant to do that in case it effects anything else I have connected via wifi? Would welcome any other suggestions you may have.
14 Nov 2023 10:10 AM
Posted by a Superuser, not a Sky employee. Find out moreThat's odd. So you connected an ethernet cable directly from the hub to your PS4 and it still disconnects? Whats the message that comes up?
16 Nov 2023 01:00 PM
@jamesn123 would you believe it now hasn't disconnected since last messaging you - from memory I think it just says 'check wifi connection' - I'll monitor it over the next few days and if it happens I'll jump back on here and message you. Many thanks for your time and help so far.
